Convert - Setting 'Decrease only' lost when saving Script
mj
Post by mj »
If you save a script for covert that has the command ...
Resize, Width: 800 pixels, Keep ratio, Bilinear, Decrease Only
the Decrease Only setting does not save in the script. Is this easy to fix?
Re: Convert - Saving Scripts
mj wrote:If you save a script for covert that has the command ...
Yes, right this option is not available for NConvert...
