De-interlace crash
Enmoku
De-interlace crash
Post by Enmoku »
The crash occursiew when trying to apply de-interlace with new fields set to duplication, eliminating even fields and apply to image is checked.
Using XnView v1.91.1 and running Windows XP SP2.
Enmoku
Post by Enmoku »
"The crash occursiew when" -> "The crash occurs when", sorry about that..
Which image ?
—> Enmoku
:) Hello !
• Please, tell us a bit more… Which image type is the culprit ?
- Could you provide a sample to test ?
• Aside : BTW, when you sign up, you may edit your messages and much more… ;)
:mrgreen: Kind regards,
Re: Which image ?
Post by Guest »
Clo wrote:• Please, tell us a bit more… Which image type is the culprit ?
Occured with any image type I tried: JPG, BMP, PNG, etc.
However, I can't replicate the bug anymore (with 1.91.1 or 1.91.2) so I have to assume my recent CPU upgrade somehow fixed that. I was using Athlon XP CPU back then (Athlon 64 X2 now) so maybe the deinterlace used some CPU instructions the old one didn't support?
I can't remember which particular images I tried it with before, so I can't really test this for certain.
Clo wrote:• Aside : BTW, when you sign up, you may edit your messages and much more… ;)
At the time when I first posted, the forum didn't allow me to register (I think the reason was my ISP's transparent proxy and the forum software thinking - based on the proxy's IP - that I was someone else who apparently was causing trouble).
Enmoku
Post by Enmoku »
... and that was me, just forgot to log-in before posting. Messing things up unusually much here >_<
