Slide Show... without subfolders?
raducoc
I want to have an option to DO NOT ADD subfolders when Im adding a folder to the Slideshow mode.
Re: Slide Show... without subfolders?
In the file dialog, you have 'include sub directories' (Add button)raducoc wrote:I want to have an option to DO NOT ADD subfolders when Im adding a folder to the Slideshow mode.
raducoc
Thanks. Yes, I know this, but There are two buttons. One is called "Add..." and the other "Add Folder...". If Im pressing "Add..." and after that Ctrl+A, XnView is adding ALL the files to the FileList, including .zip, .exe, etc. If I press the "Add Folder..." is more simple. XnView is adding only the graphic files, but also is including what is in subfolders. So, please add an option to include-exclude the subfolders also for the "Add Folder..." button.xnview wrote:In the file dialog, you have 'include sub directories' (Add button)raducoc wrote:I want to have an option to DO NOT ADD subfolders when Im adding a folder to the Slideshow mode.
