Picturenaut - HDRI Generator/Tone-Mapping
All non-XnView related: softwares, formats, imaging, photography...
Lesmo16
Post by Lesmo16 »
Picturenaut is a really impressive Freeware!
International HP: http://www.hdrlabs.com/picturenaut/index.html
German HP: http://www.picturenaut.de
BTW: There is a quite good viewer mentioned in the tools/utilities section! :wink:
Everyone who believes in telekinesis, raise my hand!
JohnFredC
Post by JohnFredC »
Wow!
John
Brian Pugh
Picturenaut . . .
Post by Brian Pugh »
Downloaded Picturenaut - now what do I do?
And what does it do, really?
Brian
JohnFredC
Post by JohnFredC »
Picturenaut combines multiple images into one. If you have exposed several photos of the same subject, each photo with a different exposure value (exposing for the darks in one, the mids in another, the highs in yet another), the combined image created by Picturenaut will select the best parts of each photo, resulting in an image with MUCH higher dynamic range than normally possible with digital OR film.
If you take the various exposures "by hand", that is: without a tripod, make sure you click the align images checkbox. Probably a good thing to leave that checked even if you do use a tripod.
There are a lot of options in Picturenaut that bear some experimentation, too.
John
Brian Pugh
Picturenaut . . .
John,
Thanks for that. Right, tripod to the ready!
Brian
Lesmo16
Post by Lesmo16 »
... and take a look here: http://www.hdrlabs.com/book/index.html
