64 bits library
ChrisG
64 bits library
Post by ChrisG »
Is the GFL library available for 64 bits Windows systems ?
Chris.
Re: 64 bits library
ChrisG wrote:Is the GFL library available for 64 bits Windows systems ?
I'll build soon a 64bits for windows...
linojr99
Post by linojr99 »
It's great to hear there will be a 64 bit version. Do we know how long before it's released?
linojr99 wrote:It's great to here there will be a 64 bit version. Do we know how long before it's released?
I'll try to release it for september
Defenestration
Post by Defenestration »
Any update on when the new version of GFL SDK will be released with support for 64-bit OS's (eg. XP Pro x64, Vista x64) and also Unicode support (at least for Windows) ?
Unicode thread: http://newsgroup.xnview.com/viewtopic.php?t=12909
linojr99
Windows 64 bit version
Post by linojr99 »
IS there an update on when we can expect to see a Windows :?: 64 bit version
Re: Windows 64 bit version
linojr99 wrote:IS there an update on when we can expect to see a Windows :?: 64 bit version
I'll try to upload a new version in 1 month (with 64 bits version)
Defenestration
Looking forward to it. Will it also support Unicode on Windows (eg. same two GFL DLL's support both ANSI and Unicode) ?
For gflLoadBitmap, gflSaveBitmap?
Defenestration
I need Unicode versions of the following functions (all which deal with filepaths) in both a 32-bit and 64-bit version of GFL:
gflSetPluginsPathname()
gflGetFileInformation()
gflLoadBitmap()
gflLoadThumbnail()
gflSaveBitmap()
gflLoadBitmapintoDIB()
gflLoadBitmapintoDDB()
There are other functions which could also have Unicode versions (eg. gflFileCreate(), gflLoadIPTC(), gflSaveIPTC(), etc.), as well as functions/data structures which could be changed into Unicode (eg. Bitmap comments, EXIF Name/Value, etc.), but I don't need that at the moment. However, it would be nice if GFL (and XnView as well) was made fully Unicode aware in the future.
Thanks in advance! :)
Defenestration
Defenestration wrote:I need Unicode versions of the following functions (all which deal with filepaths) in both a 32-bit and 64-bit version of GFL:
gflLoadBitmap()
gflLoadThumbnail()
gflSaveBitmap()
For backwards compatibility, just keep the ANSI functions named as is, and append a letter 'U' to the end of each new Unicode function (eg. gflSetPluginsPathnameU(), gflLoadBitmapU(), etc.).
linojr99
64 BIT
Post by linojr99 »
Sorry to keep asking but are you close to releasing a new Windows 64 bit version?
Re: 64 BIT
If you are interested by GFL SDK with unicode support, please contact me to test the beta version...
linojr99
64 bit
Post by linojr99 »
Sorry no I'm interested in the DLL 64 bit version same as your windows 32 bit but for windows 64 bit.
When do you believe at will be ready?
Re: 64 bit
linojr99 wrote:Sorry no I'm interested in the DLL 64 bit version same as your windows 32 bit but for windows 64 bit.
I'll release it this week
