Version 1.91.1
I have been set option>view>auto image size to fit window to image.But xnview viewer window is always bigger or cut off my pics.Is any where i forgot to set?or it is a bug?
I want to set as Irfanview default viewer window size.Window is always fit to 100% pictures size.No background grey color exist.
Thanks
Why fit window to image not work?
i want to ask one more question about option.Is only one window view opened means if i click to open a picture from explorer.The new viewer window will use a already exist xnview window?And no two or more xnview viewer window exist at the same time.
But why i no matter tick it or not.When i open picture from explorer.xnview is always open a new window.How come is it?
OK,Now i found how it is working.Anonymous wrote:i want to ask one more question about option.Is only one window view opened means if i click to open a picture from explorer.The new viewer window will use a already exist xnview window?And no two or more xnview viewer window exist at the same time.
I think better replace "only one window view" to "disable multi tab viewing" may be better.Because user may easy to cofuse it with "only one instant function" function.
