Is there any way to add multiple tagged files to categories?
I suppose to drag and drop the tagged files to categories to add, but I failed.
I think this is a useful function that XnView misses, would you consider to add it?
Request: Add tagged files to categories.
Nelson
Nelson
JohnFredC
Nelson
Right.xnview wrote:Not easy. If you have tagged files, so the drag&drop must use these files instead of selected files, right?Nelson wrote:Is it possible in the future version?
But what I don't understand is:
Since you can copy/move the tagged files instead of selected files, why can't this feature be implemented?
I have not write that i can't implemented itNelson wrote:Right.xnview wrote:Not easy. If you have tagged files, so the drag&drop must use these files instead of selected files, right?Nelson wrote:Is it possible in the future version?
Nelson
Nelson
Good :pxnview wrote:What do you think if it works like that:
* if we have only tagged files, drag&drop works on tagged files
* if we have only selected files, drag&drop works on selected files
Do you mean to move both tagged and selected files?xnview wrote:* if we have tagged & selected files, drag&drop check if the drag item is in tagged or selected files
If so, that would be a good idea.
But under what circumstance does user have to both tag and select files?
No, only drag tagged files if the dragged item is in dragged list, and the same for selected...Nelson wrote:Do you mean to move both tagged and selected files?xnview wrote:* if we have tagged & selected files, drag&drop check if the drag item is in tagged or selected files
Nelson
OK, this would also be a good alternative.xnview wrote:No, only drag tagged files if the dragged item is in dragged list, and the same for selected...Nelson wrote:Do you mean to move both tagged and selected files?xnview wrote:* if we have tagged & selected files, drag&drop check if the drag item is in tagged or selected files
Sorry for replying late, I'm in the army.
