Relative offset to text position
autocross
Post by autocross »
the suggestion is for the 'add a text' transformation.
If you choose an other position than custom, the X/Y fields bellow have no impact.
the suggestion is that the X/Y field is used as relative position to the one choosen in the position combo box.
For exemple:
if you choose 'bottom right', and X=-10, Y=-10, the added text will be incrusted 10 pixels higher et more left than the actual position of 'bottom right'
My english is very bad, so i put it in french too:
ma suggestion touche la transformation 'ajouter un texte'. Actuellement, si vous choisissez une position autre que personnalisée, les champs X et Y n'ont aucun impact.
La suggestion et d'utiliser les champs X et Y comme position relative par rapport à celle choisie dans le combo 'position'.
Par exemple:
si vous choisissez 'En bas, A droite', et que X=-10 et Y=-10, le texte sera incrusté 10 pixels plus haut et à gauche que la position définie par le combo 'position'
Ceci me permettra de créer des fond noir pour faire ressortir plus les textes incrustés.
Thanks a lot for your work
Merci beaucoup pour le travail accompli.
Olivier HOT
nconvert or XnView?
Welcome to the forum, autocross, and thank you for your English and French post. :-)
Is this an XnView or a nconvert problem? (In the subject you write "nconvert" but the problem sounds more like XnView).
autocross
Post by autocross »
May be it's xnView...
The distrib I've installed on my PC should integrate nConvert, but I don't know how to check it.
As I did an image convertion, I thought it was nConvert but I'm probably wrong... I've install XnView yesterday for the first time so I'm not very tough with it...
Thanks for your answer
Olivier HOT
