IPTC resizable dialog
w84100
Post by w84100 »
Hi all,
Yes i used te search first but found nothing.
I miss one posibility for the IPTC Dialog.
I use normaly categories and keywords in IPTC to categorise my pictures. The problem i have is that in the dialog the picture itself is so small that persons could not be identified very well. My proposal is to make this dialog resizable to increase if necessary and resize the picture in the dialog in the same amount as the dialog was increased.
Re: IPTC resizable dialog
w84100 wrote:Hi all,
Ok, i'll try to do that
