Bug in gflSoften? Getting AVs
MaierMan
Post by MaierMan »
Me again :P
I recently upgraded most of my programs to use GflSDK2.20.
One of my Applications (SimilarImages - that dupe checker), now crashes whenever it comes to the dataset generation routines.
I just recompiled and linked against Version 2.20... After switching back to 2.11 it everything works well again.
I traced the call stack and it seems gflSoften "started" an Access Violation that then will be raised in later gflFunction calls.
Although it is no problem to call gflSaveBitmap right after gflSoften.
My code is (Borland C++Builder6 fully patched, C++, Win32 (XP Pro SP1 Box)):
void __fastcall ApplyFilters(GFL_BITMAP **BMP)
        gflEqualizeOnLuminance(*BMP, NULL);
        /* "Working" (means, not complaining about failures) but introducing the crash */
        gflSoften(*BMP, NULL, 33);
        /* Crash  */
        gflNormalize(*BMP, NULL);
        gflAutoCrop(*BMP, NULL, NULL, 85);
I furthermore tried to get it running using the 2nd Parameter to "Soften" it to another image and pull it back afterwards.
Didnt work too.
(running it for debugging in apps main thread)
Another testcase performed by a MSVC 6 (SPs + ProcessorPack) build...
Simplied version of what I do in my application until it crashes.
// gflsoftentest.cpp : Defines the entry point for the console application.
#include "stdafx.h"
#include "libgfl.h"
#include "libgfle.h"
void ApplyFilters(GFL_BITMAP **BMP)
        gflNormalize(*BMP, NULL); // crashes
        gflAutoCrop(*BMP, NULL, NULL, 85); // crashes (when gflNormalize is commented out)
int main(int argc, char* argv[])
	gflLibraryInit();
	gflEnableLZW(GFL_TRUE);
	GFL_BITMAP *BMP;
	GFL_FILE_INFORMATION fileinfo;
	GFL_LOAD_PARAMS params;
	GFL_SAVE_PARAMS sparams;
	gflGetDefaultThumbnailParams(&params);
	params.Flags |=
		GFL_LOAD_HIGH_QUALITY_THUMBNAIL
		| GFL_LOAD_SKIP_ALPHA
		| GFL_LOAD_PREVIEW_NO_CANVAS_RESIZE
		| GFL_LOAD_FORCE_COLOR_MODEL
	params.ColorModel = GFL_RGB;
	gflGetDefaultSaveParams(&sparams);
	sparams.FormatIndex = gflGetFormatIndexByName("jpeg");
	gflLoadThumbnail(
		"test.jpg",
		420,
		420,
		&BMP,
		&params,
		&fileinfo
	gflSaveBitmap(
		"th1.jpg",
		BMP,
		&sparams
	ApplyFilters(&BMP);
	gflSaveBitmap(
		"th2.jpg",
		BMP,
		&sparams
	gflFreeBitmap(BMP);
	gflFreeFileInformation(&fileinfo);
	gflLibraryExit();
	return 0;
Same AVs.
(But works without gflSoften call)
Cheers
Nils
Re: Bug in gflSoften? Getting AVs
MaierMan wrote: Another testcase performed by a MSVC 6 (SPs + ProcessorPack) build...
Same AVs.
I've tested with your code, and no crash :-(
I load a jpg RGB file.
MaierMan
Post by MaierMan »
Same AVs.
I checked the same code again with MSVC7 (.Net) this time.
And it crashes...
Maybe it's something on my box?
I both times used the your distributed .libs and RELEASE config.
The dlls are located in my sys32 dir (not in the project dir)...
Thats all I currently can say...
Always the same Message:
Unhandled exception at 0x10004a8c in gflsoftentest.exe: 0xC0000005: Access violation writing location 0x00130110.
That test case project (incl. the test jpg and the compiled exe) is available here:
http://celebnamer.celebworld.ws/xnview/ ... entest.rar
Ill do some debugging now...
And see if I get some more information by watching the memory allocations (LibraryInitEx).
(But I never was a champ when it comes to debugging ROFL)
MaierMan wrote:I checked the same code again with MSVC7 (.Net) this time.
And it crashes...
With your code and Visual C++ 6, no crash :-(
Strange, my system is Win2K. Do you have the problem with all pictures?
MaierMan
Post by MaierMan »
And it crashes...
I tested various files (but only jpg files I have to admit).
Always the same AVs.
Furthermore I gave the EXE to a buddy that runs XP too...
The program crashes (without notice... No Debugger on that system).
MaierMan wrote:
And it crashes...
Ok, right. With current beta, i've not the bug.
MaierMan
Post by MaierMan »
xnview wrote:Ok, right. With current beta, i've not the bug.
Yep...
Compiled and linked well.
Execution succeeded without problems (for my testcase).
Thx for the fast fix!
Will you release new version soon?
Or will you release a version 2.21?
Yep...
Currently beta, perhaps release in december.
