Conversion fails: Can't open file
Nilesh
Post by Nilesh »
fallowing is the error i get when using version:
** NCONVERT v4.79 (c) 1991-2007 Pierre-E Gougelet (May 16 2007/10:54:38) **
Version for Linux x86 (X11) (All rights reserved)
** This is a freeware software (for non commercial use)
Error: Can't open file (convert)
Error: This output isn't possible (not yet implemented) (1.eps)
Error: Can't open file (01.jpg)
or i would get this other error if i use 64 version..
/lib64/libc.so.6: version `GLIBC_2.4' not found (required by /nconvert_new_test/nconvert64)
Yet i have already libc, not it worked fine in older version not the new one.
thanks,
Nilesh
Nilesh wrote:fallowing is the error i get when using version:
Which command line do you use?
Which linux do you have?
Nilesh
Post by Nilesh »
sorry for my very late responds,
the command line was a simple convert image from esp to jpg.
ex of command used:
nconvert -out jpeg -o 1.jpg 1.eps
- Linux 2.6.16.27-061216a
thank you!
Nilesh
Post by Nilesh »
Forgot to say, the issue is still not solved, any suggestion how to resolve the issue? upgrade linux? or what update am i missing that is causing the issue ?
thanks,
Nilesh
If you use
you obtain
** NCONVERT v4.79 (c) 1991-2007 Pierre-E Gougelet (May 16 2007/10:54:3Cool **
Nilesh
Post by Nilesh »
Thank you for pointing that out,
I narrow the issue down to JPEG format.
when i do EPS to TIFF, it works fine..
Good : ./nconvert -out tiff 001.eps
Bad: ./nconvert -out jpeg 001.eps
issue happens in 4.79 (not in older version)
i try to convert a tiff in to jpeg (ex: eps > tiff > jpeg) still not working for me, any other suggestion with JPEG issue?
  Error: This picture cannot be written using this format (001.eps)
Thank for your help! and suggestions,
Nilesh
Nilesh
Post by Nilesh »
I did more testing and found the issue with this file:
source eps file :
http://people.scs.fsu.edu/~burkardt/data/eps/tutte.eps
Issue : new version(not work) vs old version(worked)
./nconvert -out jpeg tutte.eps
  Error: Don't know how to read this picture (tutte.eps)
VS older version -
../nconvert -out jpeg tutte.eps
** NCONVERT v4.76 (c) 1991-2007 Pierre-E Gougelet (Feb  9 2007/14:57:17) **
Conversion of tutte.eps into tutte.jpg OK
hope that helps us resolve the issue, or track the issue,
Nilesh wrote:I did more testing and found the issue with this file:
source eps file :
Ok, send your email by PM
