hallo,
leider bietet XNView zum Export der slideshow nur das
Dateiformat EXE und SRC an.
Ich würde diese aber gerne als MPG abspeichern.
Bietet XnView hierzu ein Plugin oder hat jemand
einen Tip für mich wie ich aus dem SCR-File ein
MPG bekomme?
Habe es mit SUPER, TmpGenc, Stoik und MediaCoder
schon ohne Erfolg versucht.
Danke für Eure Hilfe
Norbert
Slideshow: im Movie-Format [partly German]
Dreamer
I think you're asking for slideshow export in video format (MPG). Please check this topic.
I don't think there is another way / plugin.
BTW Please use English next time, if possible.
Dreamer
nklaer
Create AVI file, Export to PDF file, Export to Flash file, Create CD/VCD/SVCD
And add these items (and Create EXE and Create screensaver) to Create menu (also 'Export to' should be Create (PDF/Flash)), since it's a bit hidden now (in Slide Show). Slide Show window and appropriate dialog would be opened.
thanx for your response,
i've installed xnview 1.91, but can't see any menu-point that is called something like "create pdf/flash"
have i to install several plugins? i'm wondering if i haven't understand how
to create i movie-file out of the slideshow-file.
creating a slideshow with sound is very easy in xnview, but i want to
show this slideshow on tv by my mediabox, so i have to convert it
in mpg.
sorry, that i first wrote my question in german, but my english isn't
very well.
Dreamer
No, no, that link is just a request, it's a former XnView Deluxe feature, shareware version of xnview. Since when develoment of this version has been stopped, some exclusive deluxe feature have been implemented to free xnview version. Video export hasn't been added yet, you can only support it in that topic. Perhaps it's not too hard to implement it, I see now that Pierre has replied "Yes" there, but I'm not sure what it means, it was more than a year ago.
So please add your support in that topic. I'll change the first post - I'll add MPG.
BTW do you need MPEG1, or MPEG2?
Edit: Perhaps you could try Evolvable EvoCapture (freeware) as workaround.
Dreamer
