Changing DPI values
Changing DPI values
Post by Guest »
I'm having troubles change the DPI values of an Image that I load into 'GflAX', for example:
when I load an JPEG Image:
pixels: 4892 x 1762 (x - y)
DPI: 300 x 300 (x - y)
I need to resize it to a smaller image, and lower the DPI value.
I resize the image to 500x180 pixels. nothing goes wrong here,
But when I change the Xdpi and Ydpi value to 180.
It only changes the Xdpi value. even if I only set the Ydpi value to 180.
the result DPI will always be: 180x300.
Does someone now how to correct this, or is it a bug?
Beste Regards,
Tyhrstan van den Berg.
Re: Changing DPI values
Anonymous wrote:Hello,
Ok, a bug, i fix it asap
Post by Guest »
Thanx,
I'm looking forward to the release,
Regards,
T.vdberg
Post by Guest »
When will the bug be fixed?
Thanks,
A.Weber
Anonymous wrote:When will the bug be fixed?
New version will be released next week.
