"Archive" zip Add-ons do not work properly!
TAUTO
Post by TAUTO »
It is appear that "Archive and "Zip" Add-ons do not work properly. When I try to open .zip files appears the following message:
Format of the file (filexxx.zip) could not be determined
The same happens when try to open .rar files! :x
Re: "Archive" zip Add-ons do not work properly!
TAUTO wrote:It is appear that "Archive and "Zip" Add-ons do not work properly. When I try to open .zip files appears the following message:
Could you post or send me a file?
