Ok, I got windows vista a while after it first came out and if there is one MAJOR annoyince in it, its by far the "Windows photo gallery" pic viewing program it comes with. By this point i was use to and loved "Windows Picture and Fax Viewer", alltho not hugely different from good old fax viewer, the photo gallery is lacking the one major ability to view gif files properly (as in moving ones).
So far I've got XnView set up about perfectly to act in the way I need it to (about the same as windows fax viewer), and I'm glad to say its even better in a lot of ways.
So down to my question at hand, when viewing images and using the "next file" (or just hiting the right and left keyboard keys.) when I reach the end of a file of pics the "next file" button becomes 'grayed out' and unusable, where I'd like to to warp back to the first picture in the file (like Windows Picture and Fax Viewer, Windows photo gallery, IrfanViewer, and most other picture viewing programs do). Is there an option I am just not noticing or a hack around to make XnView do this?
"next file"ing over from the last pic to the first
There is one
—> kenaz
Hello !
• Tools menu >> Options (or F12 key) >> View >> Misc. tab >> Tick the box : “Loop on the file-list”
Kind regards,
