After the installation XnView puts all its settings into the folder
C:\Documents and Settings\M\Application Data\XnView
How can I permanently move ALL the files from the location above to
e.g. a subfolder of XnView e.g.
D:\software\xnview\mysettings\
In options->Interface->Toolbar I found only the entry field for the toolbar but there are other setting files there as well.
How can I move them ALL in one step ?
Peter
How to move ALL settings from "App. Data" to other
pstein
Re: How to move ALL settings from "App. Data" to o
Option/Integrationpstein wrote:After the installation XnView puts all its settings into the folder
Peter
