Problem with .png file.. in 1.9.2 release
Dret
Post by Dret »
In this new 1.9.2 release appear to me this proplem with visualization of thumbnails for some .png file:
when i browse a folder with .png file, at fisrt time the thumbnails appear as well but in a second browsing they became orribly corrupted (with strange pink lines that cover the image)...
...curiously it happens only with some of them...
Only one thing: I made the upgrade from previously version (1.9.1) by copying the .ini file... to restore the old settings...
Can you suggest me a solution...??
Thanks!!
Bye!
Dret.
Don't Panic!!!
Re: Problem with .png file.. in 1.9.2 release
Dret wrote:In this new 1.9.2 release appear to me this proplem with visualization of thumbnails for some .png file:
Could you post some png with the problems?
Dret
Post by Dret »
Here the images:
N°1 During first folder view (with empty cache) images are correctly diplayed.
N°2 In a next view (when the thumbnails are displayed again) they are corrupted.
BEWARE: the same problem also appear in some .psd file format.
The program has the same setting of the previous 1.9.1 (I use always the stand-alone version with setting stored in .ini file), and the old one is not affected by this problem...
Thanks!!
Bye.
Don't Panic!!!
Dret wrote:Here the images:
Thanks!!
Bye.
Could you send me your icons folder, please?
Dret
Post by Dret »
xnview wrote: Could you send me your icons folder, please?
The .png icons are inside this archive with others two .psd files with the same problem: HERE!
Bye!
:mrgreen:
Don't Panic!!!
Bye!
:mrgreen:
I have no problem with your pictures. Try to clean the cache, but don't use old xnview version!!
Dret
Post by Dret »
xnview wrote: I have no problem with your pictures. Try to clean the cache, but don't use old xnview version!!
Yes I removed the cache manually... and not... a lot of time... but the problem still exist...!! :|
Don't Panic!!!
:-( Could you send me your xnview.ini? Which os ?
Dret
Post by Dret »
Os is Win2000
HERE!the .ini file
Thanks!
Bye.
:mrgreen:
Don't Panic!!!
Dret wrote:Os is Win2000
HERE!the .ini file
Thanks!
Bye.
:mrgreen:
There is a problem with your link!
:arrow: Pierre:
  1. Go to Base64 Online.
  2. Copy-paste the string below to the textbox.
  3. Select decode the data from a Base64 string (base64 decoding).
  4. Select export to a binary file and enter xnview.ini.rar as the filename.
  5. Click the Convert the source data button.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 TC
:arrow: Pierre
:) hello !
• Simpler : Use Total Commander to decode directly the copied MIME file above…
… and to unpack the RAR… :P
:mrgreen: KR
HERE!the .ini file
Ok, with your ini, i can reproduce it!
Ok, i understand the problem. You can't store 32bits thumbnails in a cache compressed in jpeg, so please try the ZIP compression for the cache, i'll fix it
