XnView can not read NEF-Files created by Capture NX
Nikwolf
Post by Nikwolf »
got a problem reading NEFs (stands for "nikon electronic file format")
NEFs out of the cam (D80) works fine, but XnView mostly fails to read files created or modified by CaptureNX.
Any clue?
Nikwolf
Re: XnView can not read NEF-Files created by Capture NX
Nikwolf wrote:Hi,
Any clue?
Nikwolf
Yes, it's a known problem, but could you send me a sample?
Nikwolf
Post by Nikwolf »
Hi Pierre,
example file sent to your webmaster address.
Regards,
Frank
scw2wi
Post by scw2wi »
Hi Pierre,
Nikon has developed a RAW Codec that may be used to read NEF-Files.
Maybe it helps, but it's only made for Vista.
http://nikonimglib.com/nefcodec/
Walter
