Cannot read WMF: 'Not enough memory'
vykupitel
Post by vykupitel »
I have latest version of XnView and I'm not able to read WMF file. When I try to open WMF file I get message: Not enough memory.
Re: I cannot read WMF
vykupitel wrote:I have latest version of XnView and I'm not able to read WMF file. When I try to open WMF file I get message: Not enough memory.
Could you send me it, please?
Does the error occur with just one file or with most/all WMF files on your system?
The same mess...
>> Pierre
:) Hello Pierre !
- I have the same :bug: under Win 98 SE. XnView 1.74
- I have sent samples via email.
:mrgreen: Regards,
Re: The same mess...
Clo wrote::) Hello Pierre !
I've not received your mail?
Sent alright
:) Hello Pierre !
- I've sent the mail alright to pierre.g…
Date: Fri, 26 Nov 2004 23:36:39 +0100
Whether is't lost really, I will resend it.
:mrgreen: Regards
Re: Sent alright
No, this mail address is no more used. Please use xnview.com
vykupitel
Post by vykupitel »
I have this error only with some WMF file on my system. They were created in VievCompanion Pro. We used this app to convert HPGL/2 files to WMF. Progs like ACDSee could read it. I hope that link will help you.
Thanks
http://www.volny.cz/vykupitel/Pictures/ ... ace_V3.wmf
Lost samples…
>> Pierre
:) Hello Pierre,
• You can get the archive of the samples directly here.
:mrgreen: Regards,
vykupitel wrote:I have this error only with some WMF file on my system. They were created in VievCompanion Pro. We used this app to convert HPGL/2 files to WMF. Progs like ACDSee could read it. I hope that link will help you.
It's because you have options/Read/WMF/High resolution
vykupitel
Post by vykupitel »
xnview wrote:It's because you have options/Read/WMF/High resolution
Yes, that's it. Thanks a lot.
Do you plan add possibility to view WMF files like vector graphic?
Yes, but not for the next release.
