Batch rename files to their file dates and times?
ghost zero
Post by ghost zero »
Is there a way to batch rename files to their file dates and times? Such as:
"[modified date time]" = 2007/08/04 12h-38m-23s.jpg
Re: Batch rename files to their file dates and times?
ghost zero wrote:Is there a way to batch rename files to their file dates and times? Such as:
cat.jpg > 2007/08/04 12:38.jpg
You can use something like "<Accessed Date [Y/M/d H:M]>"
ghost zero
anyway to make it like:
2007/08/04 12h.38m.23s.jpg
i tried using a lowercase s and it turns into an 08...
ghost zero wrote:anyway to make it like:
This filename template roughly does the job:
<Accessed Date [Y/m/d H]>h.<Accessed Date [M]>m.<Accessed Date >s
It's a bit complicated, but not too bad, I think. For some reason I don't understand (at the moment) the slashes are converted to minus chars, output is for example "2007-08-04 12h.38m.23s.jpg".
With "Replace Char" you can change the minus char to slash and get exactly what you want. But I think there should be a way in the template to get the slash... Does anyone have an explanation for the slashes?
xnview wrote:You can use something like "<Accessed Date [Y/M/d H:M]>"
Supposed to be "<Accessed Date [Y/m/d H:M]>" (with lowercase "m" for month).
ghost zero
JohnFredC
Post by JohnFredC »
Isn't a slash in a file name verboten in FAT32 and NTFS? My systems certainly won't accept it.
John
Dreamer
Post by Dreamer »
Yes it is, also these \ | / < > : ? and perhaps more.
Dreamer
Instead…
:) Hello !
• As a workaround, when I need a separator in a file-name I use often the character ¦ (Alt+0166) which is allowed. ;)
- Also when there is an alternative in the spelling, i.e. : “S¦he is…”, that shortens the strings.
:mrgreen: KR
JohnFredC
Post by JohnFredC »
I like · (alt+183) or (alt+149), though lately I have also been using periods:
For instance:
CAP·DM·V1.070809.exe
Naturally these characters don't work with all display fonts. Not an issue for me, though.
John
Also---
:) I use them too, and no font problem for me as well, I have put the MS Sans Serif “in the dust bin” !
:mrgreen: KR
Oops, correct. Filenames must not contain these characters.
ghost zero
how about adding a new code to simplify this and prevent errors? such as:
year, month, date, h m s ... renamed in such a way that the date/time alphabetizes correctly
