Artweaver-documents
Troken
Artweaver-documents
Post by Troken »
The Artweaver plugin ("XAWD.usr") does not work very well for the current version of Artweaver (disturbed colours in layers etc.). Would it be too much to ask that support for AWD-documents is implemented in XnView? I will gladly send you samples.
Re: Artweaver-documents
Troken wrote:The Artweaver plugin ("XAWD.usr") does not work very well for the current version of Artweaver (disturbed colours in layers etc.). Would it be too much to ask that support for AWD-documents is implemented in XnView? I will gladly send you samples.
XAWD is not for Artweaver format but for microsoft AWD format
Troken
Post by Troken »
Hm... when I remove "XAWD.usr" the Artweaver-documents can not be viewed in XnView. Are you sure? We've been discussing the format in another thread:
http://newsgroup.xnview.com/viewtopic.p ... =artweaver
There I was adviced to remove "Xawd.dll", is that what you are referring to?
XAWD.usr is a third-party plug-in I think, but as I mentioned, it does not work properly.
Troken wrote:Hm... when I remove "XAWD.usr" the Artweaver-documents can not be viewed in XnView. Are you sure? If I remember right, I was adviced to use "XAWD.usr" to handle Artweaver-documents in another thread.
Maybe you are referring to "Xawd.dll"?
Oh yes, but where do you found Xawd.usr???
Troken
Post by Troken »
Oh, i didn't know it
Troken
Post by Troken »
Its a nice plugin, though it is supposed to be in the "plugin"-directory. Don't know if it's new behaviour is due to new XnView-versions or Artweaver-versions. What do you make of it?
All user plugins must be in Plugins folder
Troken
Post by Troken »
So, back to the original question (without being pushy): any chanses you can make XnView read Artweaver-documents?
Troken wrote:So, back to the original question (without being pushy): any chanses you can make XnView read Artweaver-documents?
I don't how to read them, perhaps you can contact the author about your problem??
Troken
Post by Troken »
OK, I'll contact him.
Troken
Post by Troken »
The plugin is updated and works properly with 1.91.2. (I used an old version of the plugin, hence the problem). This thread might be closed.
