XnView and Edmics (.C4) file extension Not working?
CustomPowerSystem
Post by CustomPowerSystem »
Under the supported formats its listed there but when i download the full version and download all the extension packs i still couldnt find Edmics (.C4), it is still not listed in the supported formats in the program!! Can someone help? Thanks
foxyshadis
Post by foxyshadis »
Do you have "Use all formats available" checked in Options->General->Operations tab? Most of the uncommon formats are turned off by default.
