XnView v1.74 Resize DPI Bug
ckit
Post by ckit »
Steps:
1. Load a 800x600 image (any image maybe) into XnView View mode
2. Choose Resize -> Standard Size -> 1600x1200
3. Change the DPI by going up by 1,2 or 3 (73,74 or 75dpi)
4. Change the DPI back to 72dpi
5. Screen Size now says "1599x1200" it should be "1600x1200"
I can re-produce this bug easily.
Sigh, another bug related to this...
Steps:
2. The Resize screen says 71dpi when it should be 72dpi
3. Go back and check image info and it says the image is 72dpi by default.
Some MAJOR calculation bugs here.
Re: XnView v1.74 Resize DPI Bug
ckit wrote:Steps:
Ok, i'll fix ti.
Steps:
I can't reproduce it. You load a picture in 72 dpi, and in the resize dialog, you have 71 as DPI?
ckit
Post by ckit »
xnview wrote:
ckit wrote:Steps:
Ok, i'll fix ti.
Steps:
Yes, thats right.
It only occurs with "mh.jpg - http://www.in-tra.com.pl/~lukasz/mh.jpg" other pictures are fine.
ckit wrote:
xnview wrote:
ckit wrote:Steps:
Ok, i'll fix ti.
Steps:
Yes, thats right.
Ok, i'll fix it
ckit
Post by ckit »
I just checked the picture with IrfanView,
DPI says 72dpi BUT the EXIF info says the DPI is 71dpi which is where the problem is!!!!
ckit wrote:I just checked the picture with IrfanView,
Oh ok, if you have Options/Read/Use EXIF DPI...
ckit
Post by ckit »
Ah now I understand, I didn't know that option existed.
Thank you for pointing it out.
