unable to add folder in batch conversion
madnag
Post by madnag »
have been unable to add folder in batch reconversion. used to work before for dicom files, but is not working with newest xnview version 1.9 full or en.
is there any solution or fix possible?
Re: unable to add folder in batch conversion
madnag wrote:have been unable to add folder in batch reconversion. used to work before for dicom files, but is not working with newest xnview version 1.9 full or en.
You means that "add folder" doesn't add dicom files? works for other format?
