full screen mode : next image or previous image crashes
Markorki
Post by Markorki »
I've been using 1.90 almost since the day it has been available. I wanted to try 1.91, the same way I always do : saved my xnview.ini to a data partition as xnview070817.ini , uninstalled 1.90, installed 1.91 in a brand new c:\programfiles\xnview folder, and reinstalled 1.90 inc:\programfiles\xnview_190. For both, I proceeded so :
- in tools/options, selected : use xnview.ini in xnview folder
- exited xnview
- pasted the saved xnview070817.ini as xnview.ini, and tested.
The .ini is here ( I use win98SE-lite ) :
http://cjoint.com/data/irpsMBIflL.htm
In 1.90, if i go full creen, then the arrows display next or previous image.
In 1.91, if i go full creen, then the arrows crash xnview ( "opération non conforme", on french system ;-)
Dommage, l'était sympa cette planète ;-(
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=51865#51865]XnView 1.91.3[/url]) wrote:The Win95 is not available, i have some problems. So currently, only the 1.90 is available for win95
Firebadger
Post by Firebadger »
I have exactly the same problem. It crashes when scroll to the next image in fullscreen, however going upwards to the previous picture doesn't result in a crash.
I use 1.91.3 sv
Firebadger wrote:I have exactly the same problem. It crashes when scroll to the next image in fullscreen, however going upwards to the previous picture doesn't result in a crash.
I use 1.91.3 sv
Yes, a new bug in 1.91.3!
ckit
Post by ckit »
I've just discovered this bug too, dam annoying!
ckit wrote:I've just discovered this bug too, dam annoying!
Yes, i'll release a 1.91.4 next week
ckit
Post by ckit »
Thank You, I can't wait for it!
rip_pit
Post by rip_pit »
xnview wrote:Yes, i'll release a 1.91.4 next week
thank you much for this great app. I also got the bug too and i'll wait for 1.91.4 to be released.
Great job !
