Hallo,
I work with XnView 1.91.3 and with WinXP Home/Professional.
The option 'Explorer' in the Context-Menu from the tree, don't start the explorer under WinXP professional. Under WinXP home the explorer will be started. Perhaps this comes, because differ paths. (c:\winnt and c:\windows)
Can't open explorer in tree
OK here
• I'm using XP-Pro SP1, that works here. It takes time though, let's say 5…6 seconds about.
- P-IV @ 2.4 GHz - 512 MiB RAM. SATA HD.
• Aside : BTW, I never use Win Explorer… I use Total Commander for ages,
and now one can even set a button for it (or any other programme) in the main tool-bar of XnView…
Dreamer
