Hello
it seems that DWF-Format (Drawing Web Format by Autodesk) is still not supported by XnView.
Maybe there is a simple way to use it:
DWF is a web-format which can be displayed by Internet Explorer, and this is a function which is used by a viewer-plugin of TotalCommander:
http://www.totalcmd.net/plugring/ieview.html
Maybe XNView can use this funtionality too?
Viewing DWF - using functions of Internet Explorer
Peter2
Re: Viewing DWF - using functions of Internet Explorer
Ok, i'll checkPeter2 wrote:Hello
Peter2
Hello Pierrexnview wrote: Ok, i'll check
something new with this idea?
Peter
