XnView (V1.91.3, lib 4.81) doesn't seem to currently support Webshots wb1 files, though looking at previous forum posts it looks like older versions possibly did(?) A few of my wb1 files are viewable in XnView, but only in thumbnail format. Looking at the forum sticky on command line options of nConvert it looks like wb1 files are not supported, just wbc. Is that right? Will a wb1 file viewer be available sometime?
Thanks.
Pablo
Webshots wb1 files - no conversion in 1.91.3
Re: Webshots wb1 files - no conversion in 1.91.3
Enable option/General/Use all formatsPablo wrote:XnView (V1.91.3, lib 4.81) doesn't seem to currently support Webshots wb1 files, though looking at previous forum posts it looks like older versions possibly did(?) A few of my wb1 files are viewable in XnView, but only in thumbnail format. Looking at the forum sticky on command line options of nConvert it looks like wb1 files are not supported, just wbc. Is that right? Will a wb1 file viewer be available sometime?
Thanks.
Pablo
FAQ "Does XnView support graphic format .xyz?" provides related info.
