jp2 are not displayed with restricted account
Nikwolf
Post by Nikwolf »
Hi!
It seems that jp2-files are only displayed if the user has administration rights.
How to create the problem:
XnView with JPG-2000 support, account with restricted (=not admin) rights
1. create a jp2-file in XnView
-> file is not displayed in browser
2. log out from user account
3. change account type to administrator
4. user logs back in
5. start xnview
-> jp2-file *is* displayed
Regards,
Nikwolf
Re: jp2 are not displayed with restricted account
Which JPEG 2000 plugin do you use? Lurawave or Jasper?
Nikwolf
JPEG 2000 Plugin
Post by Nikwolf »
I think I am using the JasPar-Plugin. It's the one that comes together with the standard download archive.
Regards,
Nikwolf.
xasx
Post by xasx »
I can confirm this under Windows Vista. Only if you run XnView as an administrator you will be able to see both thumbnail and image(/preview).
Is there any workaround yet?
