performance problem with .crw file
Post by Guest »
hello,
i'm using xnview only for a short while, and i really like it.
but i have a problem when displaying crw files - when doubleclicking a thumb, or also when clicking "next picture" status bar shows about 5% finished and then it takes about 10seconds till image will be displayed....
would be nice if somebody could help
greetings
Roman
Re: performanceproblem with crw - file
Anonymous wrote:hello,
greetings
Roman
You can load preview option/View/Camera RAW
hugofant
Post by hugofant »
hello again and thanx for answering so quick....but camera raw in "options/browser/preview" is already set to "half size"....changing it to "full size" didn't make a difference.
maybe this is helpfull: my file are CAONON EOS 300D raw pictures....
hugofant wrote:hello again and thanx for answering so quick....but camera raw in "options/browser/preview" is already set to "half size"....changing it to "full size" didn't make a difference.
No, use option/View/Camera raw, and try 'thumbnail'
Post by Guest »
found it - works fine.
thanks a lot!
roman
