Bug when removing any picture
WebCoder
When removing any picture in XNView, programm window becomes not active, hidden after other windows on desktop. OS Windows Vista Home Prem 64, tested XNView 1.91 and 1.91.3.
-stupììt-
Same problem
I have the same problem with 1.91.5 and vista ultimate 64-bit
Deleting picture in full screen deactivates the window.
A bit annoying when looking through a some pictures and deleting the low quality ones.
Using F11 to enter full screen and del-key to delete pictures work ok.
If I open a picture by doubleclicking on it,en press del key to delet it. The pictures gets deleted. But the XnView window comes behind another window, the window used last before XnView gets in front of XnView window.
Just now I noticed that if I have a browser-tab in XnView it also works well. Even if the browser tab is not active.
If I close the browser tab, I get the same problem back again.
So you have only this bug if you double click on a picture in windows explorer, (start xnview in fullscreen - edit), and delete the picture?Anonymous wrote:Using F11 to enter full screen and del-key to delete pictures work ok.
It is not just by starting XnView by clicking on a picture.
I also can start XnView, in XnView browse to a folder with pictures.
Deleteing pictures now works ok.
If I open a picture by doubleclicking in XnView browser on it or hitting enter in XnView browser and then closing the XnView browser tab.
Then pressing delete to delete the picture. I got a question "Would you like to move to Recycle bin"
Selecting yes this lead to XnView not getting back in focus, instead the window behind XnView.
