[since 1.91.4] msg tif image contains multiple pages lost?
klaus2
Post by klaus2 »
Hi Pierre,
Big thanks for this very excellent program!
The following is not a real problem for me, but i note it because it might be not intended:
Viewer:
- going backward to prev image which is a tif image with mulitple pages: message box appears ("this is an image with mulitple pages ..")
- going forward (next image) to the same image: the msg box indicating multiple pages does no longer appear (since 1.91.4)
My inifile is a copy from 1.91.3 .. problem here?
Best Regards!
klaus2
PS Test case is image.tif from the SDK
No message
—> klaus2
:) Again…
• I tested with the following TIFs (from the SDK) :
img0.tif
img1.tif
img2.tif
img3.tif
but I don't get any message simply browsing the folder <– –> - that seems normal - both in 1.91.4 and in the old 1.82.4.
- Normally, such a messge appears only when you ask for save a TIF, AFAIK…
• I keep always my previous INI too, no problem with that version.
:mrgreen: VG
klaus2
Post by klaus2 »
Hi Clo,
thanks for response!
Cannot confirm .. pls try the following comparison between any version before 1.91.4 and 1.91.4:
- In the browser, select the predecessor file (previous file) for the TIF file in speech (image.tif).
- DblClick to view it
- In Viewer press PgDown (next file) for to skip to the TIF file
==> with versions before 1.91.4, i see the "multi-page" message box .. you too??
//// Pls note that i never responded the first-time query "Do not show this mesage again" by "yes" (this might explain the difference).
==> with 1.91.4, the message box does _not_ appear (resp. does not appear at the NEXT-image navigation... but it still appears at the PREVious-image navigation ..)
It's not related to a explicit given Save command (but maybe by infile structure changes side effects??)
Best Regards,
klaus2
klaus2
Post by klaus2 »
hm, confirmed bug or user-error?
NOT multipage
—> klaus2
:) Hi again…
• I noticed that the TIFs I quote above (tested) are NOT multipage ! So, it's normal that I don't get any message.
- If you tested the same files, then it's abnormal to get the message…
- I've to test again further, but I missed time till now, sorry.
- I don't think that's a user's error, but it's not obvious to discover the cause of that issue… :?
:mrgreen: VG
Re: [since 1.91.4] msg tif image contains multiple pages los
klaus2 wrote:Hi Pierre,
Viewer:
There is a little bug if you have option/Misc/Read ahead
klaus2
Post by klaus2 »
Hi Pierre,
yup. .. confirmed, depends on this option ...
Many thanks for understanding!
klaus2
