Rename in "Find Similar Files" Results Dialog
tetro
Post by tetro »
"Find similar files" is an excellent option and very useful.
In this context, one ability is absent for me is ability to rename the files directly from results dialog (E.g. add part of name of one of files to another): the best way up to me is double click on name (similarly as it is done in Windows explorer).
It will be also useful if it it will be possible also to rename the directories the comparing pair is belong to. May be even in the same way as it is suggested to file names.
Yes, the ability to move is a way of work around, but since it starts from "root" directory, it is not very useful for renaming.
