Support for Olympus E-510
Post by Guest »
XnView is a really fine and fast viewer; the only thing I miss is that it doesn't support my Olympus E-510 raw files :( . Do you plan to support this format in one of the next versions?
Best wishes
Frank
Re: Support for Olympus E-510
Anonymous wrote:Hi,
Please send me a sample?
Post by Guest »
Hi, I'm having a similar problem. Xnview displays my .orf files but they're all noise; you can't tell at all what the image is. I have an .orf file available for download http://www.justinandmichelle.us/PC120411.ORF (8.43MB). Thanks for checking into this!
Anonymous wrote:Hi, I'm having a similar problem. Xnview displays my .orf files but they're all noise; you can't tell at all what the image is. I have an .orf file available for download http://www.justinandmichelle.us/PC120411.ORF (8.43MB). Thanks for checking into this!
It works with 1.92
j-dog83
Thanks!
Post by j-dog83 »
Thanks for the update! It works great now!
