Annoying batch behaviour!
BaldrickTheGreat
Post by BaldrickTheGreat »
One annoying thing!
An example:
If I select 100 images to perform a batch operation & all images are write protected, then 100 error messages pops up, one after the other.
And if I want to remove the write protection on them, I have to do so on all images one by one = 100 times.
If I do the same thing in In Windows, it can be done with a few mouse clicks: select, right click, properties, untag write protection. Done
Lacuna
—> BaldrickTheGreat
:) Hello ! Welcome aboard !
• XnView is not a file manager, thus the “Change attributes” function is missing.
• I think that an extra INI entry could solve the issue, something like :
OverrideReadOnly= flag
Image0 : Disabled (no change, displays the boring message, default).
Image1 : Doesn't display the overwrite message in batch operations more than only once.
Image2 : Doesn't display the overwrite message in any case.
:arrow: Pierre, Please ? :D
• Waiting for that, you could change the attributes as one go for a bunch of selected files…
…like I do i.e. in Total Commander, where it's pretty easy…
:mrgreen: Kind regards,
BaldrickTheGreat
Ok!
It´s not a major problem, but in my opinion, XnView IS a file manager (it manages images=files. or am I wrong here :-)
I don´t se any reason to have one "popup window" for every selected file.
Why not ONE single "Error: Selected Images are write protected" message.
I think ACDSee handles things like this quite well.
(I uninstalled my ACDSee 4 when I found XnView)
Anyway, I really like XnView for it´s speed.
Keep up the good work.
Troken
Post by Troken »
BaldrickTheGreat wrote: It´s not a major problem, but in my opinion, XnView IS a file manager (it manages images=files. or am I wrong here
No, you're not wrong, I totally agree. Not that I've encountered this yet but XnView should be able to handle this better. I.e. a button with "no to all" or "yes to all".
BaldrickTheGreat
Exactly my point!
foxyshadis
Post by foxyshadis »
In Explorer, the way of doing this is to hold shift when you click. Not to say it's the best method, a button or checkbox is much friendlier. A flag would be overly cryptic for something this common.
Related to the topic, the way it totally bails if you try to copy on top of a read-only image is pretty annoying, since it can just cut out in the middle of a mass file copy and you have to figure out where to restart it.
So how to fix this problem? :-)
A "apply to all" in properties to change hidden flag for a batch of files?
