Change date Dialog
ben.che
Change date Dialog
Post by ben.che »
Hello again,
Another suggestion in the "Change date" dialog : the way I can select the date I want to change would be better if it was a list of checkbox instead of a single select drop down list. This way, it would be easy to change all the dates of a picture (picture creation & change, file creation & change).
(By the way, thank you a lot for the date shifter (+ 3 minutes, etc...), it is very usefull to sync pictures from different camera that are not set to the same time!)
Ben
Re: Change date Dialog
ben.che wrote:Hello again,
Yes, perhaps a good enhancement!!!
