Inaccurate display of Photoshop files
Teresita
Post by Teresita »
I use XNView to check progress on my .psd files as I work in Photoshop Elements 4 on XP. I've just installed XNView ver 1.91.4 after uninstalling the previous version and, to my dismay, I notice that a small percentage of my .psd files appear broken/incomplete in the browser. The odd thing is that such files look ok within a slideshow.
I wish I could revert to the previous version of XNView - I never had this happen to me on previous versions. Is anyone able to give me a clue as to why I'm having this trouble? If not, could someone tell me where XNView's installation files of previous versions can be found?
Re: Inaccurate display of Photoshop files
Teresita wrote:I use XNView to check progress on my .psd files as I work in Photoshop Elements 4 on XP. I've just installed XNView ver 1.91.4 after uninstalling the previous version and, to my dismay, I notice that a small percentage of my .psd files appear broken/incomplete in the browser. The odd thing is that such files look ok within a slideshow.
Could you send me a sample?
Teresita
Post by Teresita »
I'm going to then - and thanks for giving your attention to this.
