Add Xnview to camera events ?
Argax
Post by Argax »
Hi all,
1. If you go to the windows control panel.
2. Select "Scanners and Cameras".
3. Select your camera (suppose it is plugged)
4. Choose "Properties"
5. Choose "Events"
There is a "Camera detected" event and a list of application that can receive that event.
How is it possible to add XnView to the list of apps ?
Thanks,
ckit
Post by ckit »
In XnView -> Options -> System Integration -> Add XnView as applications for USB :)
Argax
Post by Argax »
ckit wrote:In XnView -> Options -> System Integration -> Add XnView as applications for USB :)
Super cool !!
Thanks for the tip :)
Argax
Post by Argax »
Ack ! ... when acquiring images from the camera XnView does not receive any metadata (there is no EXIF in the images) :(
