Hi:
I just downloaded the latest update and can no longer see the thumbnails of Xara files (.Xar)
Any one have any ideas how I can turn them back on?
xar. thumbs missing after update
Re: xar. thumbs missing after update
Do you have enabled option/General/Use all formats?Squeakydave wrote:Hi:
Ty
- Forum Librarian
Xyzzy ([url=http://newsgroup.xnview.com/viewtopic.php?t=4941]Options' descriptions for 1.82[/url]) wrote:Use all formats available – If checked, XnView can display all avaliable file formats. Otherwise only approx. 100 most popular formats are supported, and other are treated as 'Other' (unrecognized) files. This option also limits contents of the 'Associations' and 'Write>File types' lists in Options window and file types lists in Open and Save windows.
Turning off this option speeds up XnView operations.
marsh (FAQ: [url=http://newsgroup.xnview.com/viewtopic.php?p=35553#35553]Does XnView support graphic format .xyz?[/url]) wrote:When trying Xnview, note the following option:
- General>Startup>[ ]Use all formats available
- The most popular 150 file types out of about 500 available will be used when this option is off (the recommended default setting).
- When enabled, extra file types will also appear in 'supported formats list' in program's menu.
XnView v1.91.4 (Aug 30 2007) » Tools » Options... » System integration » Associations:Olivier_G ([url=http://newsgroup.xnview.com/viewtopic.php?p=37452#37452]What's the point of 'Use all formats available'=OFF ?[/url]) wrote:I had a deeper look at that option:
-> Saving list is reduced from 63 to 50 filetypes.
- Use all formats available: on = 505 / off = 179
001 3DS Max thumbnail max
002 !> AAA logo bpr
003 !> ACE texture ace
004 !> ADEX img,rle
005 !> AIM Grey Scale ima,im
006 !> AIPD image aipd
007 !> ARF arf
008 !> AT&T Group 4 att
009 !> AT&T multigen icn
010 !> AVHRR Image sst
011 AWD awd
012 Ability Photopaint Image apx
013 !> Access g4,acc
014 !> Aces200 ace
015 !> Acorn Sprite acorn
016 !> AdTech perfectfax adt
017 Adobe Illustrator ai
018 !> Adobe PhotoParade (images) php
019 Adobe Photoshop psd
020 !> Advanced Art Studio ocp,art,pic
021 !> AirNav anv
022 !> Album bébé frm
023 Alias Image File pix,als,alias
024 !> Alpha Microsystems BMP bmp
025 !> Amapi 2d
026 !> Amica Paint ami,[b]
027 Amiga IFF iff,blk
028 !> Amiga icon info
029 !> Amstrad Cpc Screen cpc
030 !> Andrew Toolkit raster object atk
031 !> Apollo HDRU hdru,hdr,gn
032 !> ArcInfo Binary hdr
033 !> Art Director art
034 !> Artisan art
035 !> Artist 64 a64
036 !> Artrage ptg
037 !> Astronomical Research Network arn
038 !> Atari grafik pcp
039 !> Aurora sim
040 !> Auto F/X afx
041 AutoCAD DWG dwg
042 AutoCAD DXF dxf
043 !> Autocad CAD-Camera img
044 Autodesk Animator fli,flc
045 !> Autodesk QuickCAD thumbnail cad
046 !> Autodesk SKETCH thumbnail skf
047 !> Autodesk SketchUp component skp,skb
048 !> Autologic gm,gm2,gm4
049 !> Award Bios Logo epa
050 !> Axialis Screensaver (images) ssp
051 !> B3D (images) b3d
052 !> BFLI bfl,bfli,fli,flp,afl
053 !> BIAS FringeProcessor msk,img,raw,flt
054 BLP textures blp
055 BMF bmf
056 BSB/KAP kap
057 !> BYU SIR sir
058 !> Bert's Coloring bmg,ibg
059 !> Bfx Bitware bfx
060 Bio-Rad confocal pic
061 !> Blazing Paddles pi
062 !> Bob Raytracer bob
063 !> Brender pix
064 !> Brooktrout 301 brk,301,brt
065 !> Brother Fax uni
066 !> Buttonz & Tilez texture til
067 CALS Raster cal,cals,gp4,mil
068 !> CDU Paint cdu
069 CGM cgm
070 !> CImage dsi
071 !> CMU Window Manager cmu
072 !> CP8 256 Gray Scale cp8
073 !> Calamus cpi,crg
074 Camera RAW raw
075 Canon EOS-1D Mark II RAW cr2
076 !> Canon Navigator Fax can
077 Canon PowerShot crw
078 !> Cartes Michelin big
079 Casio QV-10/100 Camera cam
080 Chinon ES-1000 digital camera cmt
081 !> Cisco IP Phone cip
082 Cloe Ray-Tracer clo,cloe
083 !> ColoRIX rix,sci,scx,sc?
084 CompW wlm
085 CompuServe GIF gif,giff
086 !> Computer Eyes, Digital Vision ce
087 !> ComputerEyes Raw ce1,ce2
088 !> Core IDC idc
089 !> Corel Draw Bitmap (preview) cdr
090 !> Corel Draw Pattern (preview) pat
091 !> Corel Flow (preview) bmf
092 !> Corel Metafile Exchange (preview) cmx
093 !> Corel PhotoPaint 6.0 cpt
094 !> CoverDesigner (images) ncd
095 !> CoverDesigner Template (images) nct
096 !> Crayola art
097 !> DIV Game Studio Map map
098 !> DIV Game Studio Multi Map fpg
099 DKB Ray-Tracer dis
100 DNG dng
101 DPX dpx
102 !> Dali Raw sd0,sd1,sd2
103 !> Datacopy img
104 !> Degas & Degas Elite pi1,pc1,pi2,pc2,pi3,pc3,pi4,pi5,pi6
105 Deluxe Paint, Electronic Arts lbm,ilbm
106 Dicom dcm,acr,dic,dicom,dc3
107 Digital F/X tdim
108 !> Digital Research (GEM Paint) img,gem
109 Direct Draw Surface dds
110 !> Discorp CMP Image cmp
111 DjVu djvu,djv,iw4
112 !> DolphinEd dol
113 !> Doodle Atari doo
114 !> Doodle C64 dd
115 !> Doodle C64 (Compressed) jj
116 !> Dr Halo cut
117 !> Draz Paint drz
118 !> EA Sports FSH fsh
119 EPS Interchange Format epi,ept
120 ERI-chan (Entis Rasterized Image) eri
121 !> ESM Software Pix pix
122 !> Ecchi ecc
123 !> Eclipse tile
124 !> Edmics c4
125 !> Egg Paint trp
126 Electric Image ei,eidi
127 !> Embroidery bmc
128 Encapsulated Postscript ps,eps
129 Encapsulated Postscript(Preview) eps
130 !> Enhance Simplex esm
131 Enhanced Compressed Wavelet ecw
132 !> Eroiica eif
133 !> Everex Everfax efx,ef3
134 Explore (TDI) & Maya iff,tdi
135 FIF (Iterated System) fif
136 !> FIT fit
137 !> Face Painter fpt
138 Fast Piecewise-constant pwc
139 !> Fax Group 3 g3,fax
140 !> Fax man fmf
141 !> Faxable PCX fcx
142 !> Faxable TIFF ftf
143 !> Fenix Map map
144 !> Fenix Multi Map fpg
145 !> FileMagic mag
146 !> Flash Image fi
147 !> FlashCam Frame ncy
148 !> FlashCam frame ncy
149 FlashPix Format fpx
150 !> Flexible Image Transport System fts,fits,fit
151 !> Fontasy Grafik bsg
152 !> Fremont Fax96 f96
153 Fugawi Map fx3
154 Fuji S2 RAW raf
155 !> Fun Painter II fp2,fun
156 !> Fun Photor fpr
157 !> Fuzzy bitmap fbm,cbm
158 !> GRS16 g16
159 !> Gamma Fax gmf
160 !> GeoPaint geo
161 !> Gfa Raytrace sul
162 !> GigaPaint Hi-res gih
163 !> GigaPaint Multi gig
164 Gimp Bitmap xcf
165 Gimp Brush gbr
166 Gimp Icon ico
167 Gimp Pattern pat
168 !> GoDot 4bt,4bit,clp
169 !> GunPaint gun,ifl
170 HD Photo wdp,hdp
171 HDRI hdr,hdri
172 !> HF hf
173 !> HP-48/49 GROB gro,grb
174 !> HP-49 OpenFire gro2,gro4
175 HPGL-2 hp,hpg,hgl,plt,hpgl,hpgl2,gl2,prn,prt,spl
176 !> HRU hru
177 !> HSI Raw raw
178 !> Half-Life Model mdl
179 !> Hayes JTFax jtf
180 !> Hemera Photo Image hpi
181 !> Hemera Thumbs hta
182 !> Heretic II MipMap m8
183 !> Hi-Eddi hed
184 !> Hires C64 hir,hbm
185 !> Homeworld Texture lif
186 !> IBM Kips kps
187 !> IBM Printer Page Segment pse
188 !> IM5 (Visilog) im5
189 !> IMNET Image imt
190 !> IOCA ica,ioca,mod
191 IPLab ipl
192 !> IPod thumb ithmb
193 !> ISS iss
194 Icon Library icl
195 !> Image Capture Board icb
196 Image Magick file mif,miff
197 !> Image Speeder ish
198 !> Image System (Hires) ish
199 !> Image System (Multicolor) ism
200 !> Image Systems RLC2 Graphic rlc
201 !> ImageLab b&w,b_w
202 Imaging Fax g3n
203 !> Imaging Technology img
204 !> Img Software Set img
205 !> Inshape iim
206 !> InterPaint (Hires) iph
207 !> InterPaint (Multicolor) ipt
208 Intergraph Format itg,cit,rle
209 !> Interleaf iimg
210 !> Iris CT ct
211 !> Iris Graphics iris
212 J Wavelet Image Codec wic
213 JBIG jbg,bie,jbig
214 JBIG-2 jb2
215 JPEG / JFIF jpg,jpeg,jif,jfif,J,jpe
216 JPEG 8BIM header (Mac) jpg,jpeg,jif,jfif,J,jpe
217 JPEG-2000 Code Stream jpc
218 JPEG-2000 JP2 File Format jp2,j2k,jpx,jpf
219 JPEG-LS jls
220 Jeff's Image Format jif
221 !> Jigsaw jig
222 !> Jovian VI vi
223 Jpeg Network Graphics jng
224 !> JustButtons animated bitmap btn
225 !> KONTRON img
226 !> Khoros Visualization Image file vif,viff,xv
227 !> KinuPix Skin thb
228 !> Kiss Cel cel
229 !> Koala Paint koa
230 !> Koala Paint (Compressed) gg
231 Kodak Cineon cin
232 Kodak DC120 Digital Camera kdc
233 Kodak DC120 Digital Camera kdc
234 Kodak DC25 Camera k25
235 Kodak Photo CD pcd
236 Kodak Pro Digital RAW dcr
237 !> Kofax Group 4 kfx
238 Konica Camera File kqp
239 !> LSS16 lss,16
240 !> LView Pro lvp
241 !> LaserData lda
242 !> Light Work Image lwi
243 LucasFilm Format lff
244 !> Lumena CEL cel
245 LuraDocument Format ldf
246 LuraDocument.jpm Format jpm
247 LuraWave Format lwf
248 LuraWave JPEG-2000 Code Stream jpc
249 LuraWave JPEG-2000 Format jp2,j2k,jpx,jpf
250 !> MAKIchan Graphics mag
251 !> MGI Photosuite Project (images) pzp
252 !> MGR bitmap mgr
253 MTV Ray-Tracer mtv
254 !> Mac Paint mac,mpnt,macp,pntg,pnt,paint
255 Mac icon icns
256 Macintosh Quickdraw/Pict pic,pict,pict2,pct
257 !> Maggi Hairstyles & Cosmetics fff
258 !> Male MRI pd,t1,t2
259 !> Male Normal CT fre
260 !> Marks Russel File mrf
261 !> Mavica 411
262 !> Maw-Ware Textures mtx
263 Mayura Draw pdx
264 !> MegaPaint bld
265 !> Megalux Frame frm
266 !> Micro Dynamics MARS pbt
267 !> Micro Illustrator Uncompressed mil
268 !> Micrografx Picture Publisher 4.0 pp4
269 !> Micrografx Picture Publisher 5.0 pp5
270 Microsoft Image Composer mic
271 !> Microsoft Paint msp
272 !> Microtek Eyestar img
273 !> Mindjongg Format ipg
274 Minolta DiMAGE RAW mrw
275 !> Mobile FAX rfa
276 !> MonkeyCard pdb
277 !> MonkeyLogo pdb
278 !> MonkeyPhoto mph
279 MrSid sid
280 !> Msx 2 Screen sc2
281 Multiple Network Graphics mng
282 Multiple Network Graphics mng
283 !> NCR Image ncr
284 !> NIST ihdr pct
285 !> National Imagery Transmission F. ntf,nitf
286 !> NeoBook Cartoon car
287 !> Neochrome (ST & TT) neo
288 !> Neopaint Mask npm
289 !> Neopaint Stamp stw
290 !> NewsRoom nsr,ph,bn
291 Nikon RAW nef,mos
292 !> Nokia Group Graphics ngg
293 !> Nokia Logo File nlm
294 !> Nokia OTA bitmap otb
295 !> Nokia Operator Logo nol
296 !> OAZ Fax oaz,xfx
297 OS/2 Bitmap bmp,bga
298 !> Olicom Fax ofx
299 Olympus RAW orf
300 Open Image Library Format oil
301 !> Optigraphics ctf
302 !> Optigraphics Tiled ttf
303 !> Optocat abs
304 !> Oric Hires hir
305 !> Oric TAP tap
306 !> Os/2 Warp bga
307 !> PABX background pix
308 PAX pax
309 !> PC Paint / Pictor Page pic,clp
310 !> PCO b16
311 !> PM pm
312 !> Page Control Language pcl
313 !> Paint Magic pmg
314 PaintShopPro Browser Cache File jbf
315 PaintShopPro Brush pspbrush
316 PaintShopPro Brush jbr
317 PaintShopPro Frame pfr,pspframe
318 PaintShopPro Image psp,pspimage
319 PaintShopPro Mask pspmask
320 PaintShopPro Mask msk
321 PaintShopPro Pattern pat
322 PaintShopPro Picture Tube tub,psptube
323 PaintShopPro Texture tex
324 Palm Pilot pdb
325 Panasonic DMC-LC1 RAW srf
326 Pegs pxs,pxa
327 Pentax *ist D pef
328 !> Pfs Art Publisher art
329 !> Photo Deluxe pdd,pdb
330 Photo Filtre Studio pfi
331 !> PhotoFantasy Image fsy
332 !> PhotoFrame frm
333 !> PhotoStudio File psf
334 !> PhotoStudio Stamp stm
335 !> Photomatrix cat
336 Pic2 p2
337 !> Picasso 64 p64
338 Picture Gear Pocket prc
339 Picture It! mix
340 Pixar picture file pic,pxr,picio,pixar
341 !> Pixel Power Collage ib7,i17,i18,if9
342 !> Pixia pxa
343 Pixibox pxb
344 !> Planetary Data System pds,img
345 !> Playback Bitmap Sequence bms
346 !> Pocket PC Bitmap 2bp
347 !> Pocket PC Themes (images) tsk
348 !> Polychrome Recursive Format prf
349 Portable Bitmap pbm,rpbm,ppma
350 Portable Document Format pdf
351 Portable Greyscale pgm,rpgm
352 Portable Image pnm,rpnm,pbm,rpbm,pgm,rpgm,ppm,rppm
353 Portable Network Graphics png
354 Portable Pixmap ppm,rppm
355 !> Portfolio Graphics pgf
356 !> Portfolio Graphics Compressed pgc
357 !> Portrait cvp
358 !> Poser Bump bum
359 Postscript ps,ps1,ps2,ps3,eps,prn
360 !> PowerCard maker crd
361 !> PowerPoint (images) pps
362 !> PowerPoint Presentation (images) ppt
363 !> Print Master pm
364 !> Print Shop psa,psb
365 !> Printfox/Pagefox bs,pg,gb
366 !> Prism cpa
367 !> Prisms pri
368 Psion Series 3 Bitmap pic
369 Psion Series 5 Bitmap mbm
370 !> Punk Productions Picture ppp
371 !> Puzzle pzl
372 !> Q0 q0,rgb
373 !> Qdv (Random Dot Software) qdv
374 Qrt Ray-Tracer qrt
375 !> Quake Texture wal
376 Quantel VPB vpb
377 QuickTime Image Format qtif,qti
378 !> RIPTerm Image icn
379 !> Radiance rad,img,pic
380 !> Rainbow Painter rp
381 Raw raw,gry,grey
382 Rayshade pic
383 Red Storm File Format rsb
384 Ricoh Digital Camera j6i
385 !> Ricoh Fax 001,ric
386 !> Ricoh IS30 pig
387 !> Rm2K XYZ xyz
388 !> RunPaint (Multicolor) rpm
389 !> SBIG CCD camera ST-4 st4
390 !> SBIG CCD camera ST-X stx,st4,st5,st6,st7,st8
391 !> SPOT dat
392 SVG svg
393 !> Saracen Paint sar
394 !> SciFax sci
395 SciTex Continuous Tone sct,ct,ch
396 Seattle Film Works sfw
397 Seattle Film Works multi-image pwp,sfw
398 !> SecretPhotos puzzle xp0
399 Sega SJ-1 DIGIO sj1
400 !> Sharp GPB img
401 !> Siemens Mobile bmx
402 Sigma RAW x3f
403 Silicon Graphics RGB rgb,rgba,bw,iris,sgi,int,inta
404 !> Skantek skn
405 !> Slow Scan Television hrz
406 !> SmartDraw 6 template sdt
407 !> SmartFax 001
408 !> SmoothMove Pan Viewer pan
409 Softimage pic,si
410 !> Solitaire Image Recorder sir
411 Sony DSC-F1 Cyber-shot pmp
412 Sony DSC-F828 RAW srf
413 Sony PS2 TIM tm2
414 Sony Playstation TIM tim
415 Sony RAW sr2,arw
416 !> Spectrum 512 spu
417 !> Spectrum 512 (Compressed) spc
418 !> Spectrum 512 (Smooshed) sps
419 !> SriSun ssi
420 !> Stad pic,pac,seq
421 !> Star Office Gallery sdg
422 !> Starbase img
423 !> Stardent AVS X x,avs,mbfs,mbfavs
424 !> Stereo Image jps
425 Structured Fax Format sff
426 Sun Icon/Cursor icon,cursor,ico,pr
427 Sun Rasterfile ras,rast,sun,sr,rs
428 Sun TAAC file iff,vff,suniff,taac
429 !> Syberia texture syj
430 Synthetic Universe syn,synu
431 !> TG4 tg4
432 !> TI Bitmap 92i,73i,82i,83i,85i,86i,89i
433 TIFF Revision 6 tif,tim,tiff
434 !> TMSat image imi
435 !> TRS 80 hr
436 !> TealPaint pdb
437 !> Teli Fax mh
438 !> Thumbnail tnl
439 !> TilePic tjp
440 !> Tiny tny,tn1,tn2,tn3
441 !> TopDesign Thumbnail b3d,b2d
442 !> Total Annihilation gaf
443 Truevision Targa tga,targa,pix,bpx,ivb
444 !> Ulead Pattern pst
445 !> Ulead PhotoImpact upi
446 !> Ulead Texture (images) pe4
447 !> Usenix FaceServer fac,face
448 Utah raster image rle,urt
449 !> VIPS Image v
450 !> VITec vit
451 VRML2 wrl
452 !> Venta Fax vfx
453 !> Verity vif
454 !> Vicar vic,vicar,img
455 !> Vidcom 64 vid
456 !> Video Display Adapter vda
457 Vista vst
458 Vivid Ray-Tracer img
459 !> Vort pix
460 !> Vue d'esprit vob
461 !> WAD (Half life) wad
462 WaveL iwc
463 Wavefront Raster file rla,rlb,rpf
464 !> WebShots (images) wb1,wbc,wbp,wbz
465 !> Weekly Puzzle jig
466 Whypic ypc
467 WinFAX fxs,fxo,wfx,fxr,fxd,fxm
468 !> WinMIPS pic
469 Windows & Aldus Metafile wmf
470 Windows Animated Cursor ani
471 Windows Bitmap bmp,rle,vga,rl4,rl8
472 Windows Clipboard clp
473 Windows Comp. Enhanced Metafile emz
474 Windows Compressed Metafile wmz
475 Windows Cursor cur
476 Windows DIB dib
477 Windows Enhanced Metafile emf
478 Windows Icon ico
479 !> Winzle Puzzle wzl
480 Wireless Bitmap (level 0) wbmp,wbm,wap
481 !> Word Perfect Graphics (images) wpg
482 !> Worldport Fax wfx
483 X Windows System dump xwd,x11
484 X11 Bitmap xbm,bm
485 X11 Pixmap xpm,pm
486 XV Visual Schnauzer p7
487 !> Xara (images) xar
488 !> Xerox DIFF xif
489 !> Ximage xim
490 !> Xionics SMP smp
491 YUV 16Bits yuv,qtl,uyvy
492 YUV 16Bits Interleaved yuv,qtl,uyvy
493 YUV 4:1:1 yuv,qtl
494 YUV 4:2:2 yuv,qtl
495 YUV 4:4:4 yuv,qtl
496 !> ZX Spectrum Hobetta $s,$c,!s
497 !> ZX Spectrum Snapshot sna
498 !> ZX Spectrum standard screen
499 !> ZZ Rough rgh
500 !> Zeiss BIVAS dta
501 !> Zoner Callisto Metafile (preview) zmf
502 !> Zoner Zebra Metafile (preview) zbr
503 Zsoft Multi-page Paintbrush dcx
504 Zsoft Publisher's Paintbrush pcx,pcc,dcx
505 !> byLight bif
Ty
- Forum Librarian
XnView v1.91.4 (Aug 30 2007) » File » Save As... » Save as type:
- Use all formats available: on = 75 / off = 62
01 !> 92I - TI Bitmap
02 BMP - Windows Bitmap
03 CIN - Kodak Cineon
04 DCX - Zsoft Multi-page Paintbrush
05 DDS - Direct Draw Surface
06 DIS - DKB Ray-Tracer
07 DPX - DPX
08 ECW - Enhanced Compressed Wavelet
09 EMF - Windows Enhanced Metafile
10 FPX - FlashPix Format
11 !> FTS - Flexible Image Transport System
12 GIF - CompuServe GIF
13 !> GRO - HP-48/49 GROB
14 !> HDR - ArcInfo Binary
15 !> HRU - HRU
16 ICO - Windows Icon
17 IFF - Amiga IFF
18 IFF - Explore (TDI) & Maya
19 IMG - Vivid Ray-Tracer
20 IWC - WaveL
21 JBG - JBIG
22 JIF - Jeff's Image Format
23 JP2 - JPEG-2000 JP2 File Format
24 JP2 - LuraWave JPEG-2000 Format
25 JPC - JPEG-2000 Code Stream
26 JPC - LuraWave JPEG-2000 Code Stream
27 JPG - JPEG / JFIF
28 JPM - LuraDocument.jpm Format
29 LDF - LuraDocument Format
30 LWF - LuraWave Format
31 MBM - Psion Series 5 Bitmap
32 MIF - Image Magick file
33 MTV - MTV Ray-Tracer
34 !> NGG - Nokia Group Graphics
35 !> NLM - Nokia Logo File
36 !> NOL - Nokia Operator Logo
37 !> OTB - Nokia OTA bitmap
38 PAT - Gimp Pattern
39 PBM - Portable Bitmap
40 !> PCL - Page Control Language
41 PCX - Zsoft Publisher's Paintbrush
42 PDB - Palm Pilot
43 PDF - Portable Document Format
44 PGM - Portable Greyscale
45 !> PI1 - Degas & Degas Elite
46 PIC - Bio-Rad confocal
47 PIC - Psion Series 3 Bitmap
48 PIC - Rayshade
49 PIC - Softimage
50 PIX - Alias Image File
51 !> PIX - PABX background
52 PNG - Portable Network Graphics
53 PNM - Portable Image
54 PPM - Portable Pixmap
55 PRC - Picture Gear Pocket
56 PS - Postscript
57 PSD - Adobe Photoshop
58 QRT - Qrt Ray-Tracer
59 !> RAD - Radiance
60 RAW - Raw
61 RGB - Silicon Graphics RGB
62 RLA - Wavefront Raster file
63 SCT - SciTex Continuous Tone
64 TGA - Truevision Targa
65 TIF - TIFF Revision 6
66 VST - Vista
67 WBMP - Wireless Bitmap (level 0)
68 WDP - HD Photo
69 WIC - J Wavelet Image Codec
70 WLM - CompW
71 WRL - VRML2
72 XBM - X11 Bitmap
73 XPM - X11 Pixmap
74 YUV - YUV 16Bits
75 YUV - YUV 16Bits Interleaved
