Fullscreen text info - free color
Micha
Post by Micha »
could be nice to set a free color for the info text in fullscreen mode.
I would like, that path and name are shown very light only. For example I use a black background and can not set the text color at a very dark grey, so that the info is visible only, if the user direct look at it.
Thanks,
Micha
foxyshadis
Post by foxyshadis »
You can only set the basic 16 system color in the GUI, but in the ini or registry you can set anything you want, using the standard color codes. (Fullscreen->TextColor)
Micha
Post by Micha »
I can not find an ini file here and at the Windows registry I found no option.
Look for…
—> Micha
:) Hello !
• Here, I've in my INI file (located in the folder of the programme) :
[FullScreen]
TextBackColor=0
TextColor=16777215
• You could have an INI file at the default location, it might be :
X:\Documents and Settings\Your_User_Name\Application Data\XnView\xnview.ini
Where “X:” is the letter of your boot-disk (i.e., here it's E:).
• You may use any colour-code now, for instance:
- Decimal with "complements" like shown above (good luck!)
- Decimal as RRR GGG BBB
- Hexa as #RRGGBB
- Inverted hexa as $BBGGRR
:mrgreen: KR
Micha
Post by Micha »
Ah, thanks Claude, I found it. :)
It's not easy to set, but I found a solution. If I set 077 077 077 than I don't get a grey, I get the last seted color and my ini value control the brightness. It's ok so.
I tested to use the hex code from Photoshop like this #de1818, but it dosn't work.
Best would be, if the UI could allow to set any color. :wink:
