I use the last version of xnview 1.91.4
and use Microsoft console servizio fax ver 5.1
with the new ver of xn (not before) when print the cover is "rorrim" (mirror)
the prewiev is ok
i have only upgrade xnview
print fax cover (MIRROR)
Re: print fax cover (MIRROR)
Could you post or send the picture that you want to print?tino wrote:I use the last version of xnview 1.91.4
the prewiev is ok
tino
Hello,tino wrote:I use the last version of xnview 1.91.4
the prewiev is ok
Same problem here with xnview 1.19.4 on XP when printing a pbm file.
Preview OK.
Printing with 'Disposition - Unique meilleure adaptation à la page' -> mirror
Printing with 'Disposition - Adapter à la page' -> correct
(sorry don't know english menus)
File can be found here :http://www.teaser.fr/~bperea/images/fn6 ... 818.01.pbm
I can't reproduce this bug!!!Anonymous wrote:Hello,tino wrote:I use the last version of xnview 1.91.4
the prewiev is ok
Preview OK.
Do you print the file from browser or view mode? Do you have some special settings on print dialog?
prab
Thank you.xnview wrote:I can't reproduce this bug!!!Anonymous wrote:Hello,tino wrote:I use the last version of xnview 1.91.4
the prewiev is ok
Preview OK.
I confirm that I am in view mode (ie I open the file with a right-click).
I tested in browser mode and had no mirror problem.
No special settings for printing.
Could you contact me by PM or by email, i would like to send you a test version?prab wrote: I confirm that I am in view mode (ie I open the file with a right-click).
sunhill
print mirrored
Hi Pierre,
i can also reproduce this bug, with printing tiff files (1bit, g4 fax)
One colleague of mine was very upset after printing many mirrored drawings after the update to 1.91.4...
I had to reset to 1.91.3.
We have also a minor bug in the preview while using a network printer.
Every time you call the print dialoge, the preview is resetted to the printer defaults in terms of orientation (portrait, landscape).
So, every time we call the print dialoge, we have to set the orientation in the printing settings...
Is it possible to keep the last values? also for network printers?
Regards
SunHill
Regards
SunHill
Do you have received the version?prab wrote: I confirm that I am in view mode (ie I open the file with a right-click).
tino
