HotkeyP, custom hotkeys
And 1
Post by And 1 »
Will XnView ever have customizable keys? I hope so.
I've used hotkeyP. Is there a way to save the settings to the registry so I don't have to run HotkeyP while I run XnView?
Suggestion:
Also, I love the "Count Unique Colors" thing like in Irfanview. But I don't like how it appears in its own box, then you have to press "OK" to exit.
Dreamer
Post by Dreamer »
No, HotkeyP is an external application, but memory usage is very low, so it's not a problem to start it at Windows startup.
Dreamer
And 1
Post by And 1 »
I've got another question:
Can you make "Show Information (I)" as always ON in the viewer? And is there a code to always show the amount of unique colors to add to the Information (I)?
