Control images individually when comparing (v1.91.4)
iycgtptyarvg
Post by iycgtptyarvg »
When I'm comparing images (<SHIFT>+C tool) the icons above the images (zoom in / zoom out / ...) don't just work on the image I'm clicking them for, but does it to all the images!
Please fix this so the icons only effect the image I clicked the icons for.
Re: Control images individually when comparing (v1.91.4)
iycgtptyarvg wrote:When I'm comparing images (<SHIFT>+C tool) the icons above the images (zoom in / zoom out / ...) don't just work on the image I'm clicking them for, but does it to all the images!
Yes, normal, the 2 pictures are attached, so if you move/zoom a picture, the other one is changed too....
iycgtptyarvg
Great, hopefully you can fix it for the next release.
It's quiet annoying I have to use FastStone Image Viewer to compare similar pictures with different sizes because of this bug.
Thanks for XnView, I use it daily.
JohnFredC
Post by JohnFredC »
I've posted a "ton" of requests for the Compare functionality in XnView.
Search the forum for "Compare".
John
Post by Guest »
... please don't change it, I prefer it the way it is! (or maybe you could add a setting in the perferences for this...)
JohnFredC wrote:I've posted a "ton" of requests for the Compare functionality in XnView.
Yes, many useful requests!!!
iycgtptyarvg
Wow! If some of these feature would be implemented, I could uninstall FastStone Viewer!
Pierre, are any of these suggestions in the pipeline?
