Tag suggestion
bugmenot
Tag suggestion
I have a suggestion:
It will be great to have an option for "Select tagged" pictures.
And also, have a "tag status" mark in fullscreen and in "only one picture" view mode.
I know that I can see the status by pressing "I", but sometimes is not updated correctly, so is not acurate.
It will be nice to have a check box like in the "Explorer" viewmode.
Thanks!
Thanks!
Re: Tag suggestion
Why? If you have tagged files, a dialog box ask you for selected files...bugmenot wrote: It will be great to have an option for "Select tagged" pictures.
You can add tag in 'view info'And also, have a "tag status" mark in fullscreen and in "only one picture" view mode.
bugmenot
Re: Tag suggestion
I know, but just for not having the dialog box.xnview wrote: Why? If you have tagged files, a dialog box ask you for selected files...
The problem is that sometimes when you go "Page Up" and then "Page Down" the "Tag Status" is not updated.xnview wrote: You can add tag in 'view info'
Also will be nice that xnview stores the "Tag status" for a photo even if the app is turned off and back on.
Thanks!
Re: Tag suggestion
But if you use 'don't show again'?bugmenot wrote:I know, but just for not having the dialog box.xnview wrote: Why? If you have tagged files, a dialog box ask you for selected files...
I'll checkThe problem is that sometimes when you go "Page Up" and then "Page Down" the "Tag Status" is not updated.xnview wrote: You can add tag in 'view info'
Sorry i don't understand what you means?Also will be nice that xnview stores the "Tag status" for a photo even if the app is turned off and back on.
bugmenot
Re: Tag suggestion
But after I check, I'll never have the option again to "don't show again"xnview wrote:But if you use 'don't show again'?
If I go off the folder or shut down the XnView, the "tag status" of each photo is forgoten by the XnView.xnview wrote: Sorry i don't understand what you means?
What I suggest is that the XnView remembers the "tag status" no mater I go to other folder or shut down the app.
Have you tried how Fast Stone Viewer tag function works?
Hey, it's just a suggestion
Re: Tag suggestion
For me, the tag are used when you view a folder as a temporary selection, if you want to keep it, category is better...bugmenot wrote:If I go off the folder or shut down the XnView, the "tag status" of each photo is forgoten by the XnView.xnview wrote: Sorry i don't understand what you means?
bugmenot
bugmenot
Re: Tag suggestion
The tag status is not updating on the 1.91.5 in the last picture of a folder.xnview wrote:I'll checkbugmenot wrote:The problem is that sometimes when you go "Page Up" and then "Page Down" the "Tag Status" is not updated.xnview wrote: You can add tag in 'view info'
Can you check it?
bugmenot
foxyshadis
jis
Re: Tag suggestion
I haven't this problem in 1.91.5.bugmenot wrote:The tag status is not updating on the 1.91.5 in the last picture of a folder.
Can you check it?
pepemosca
I go to the last picture of a folder, press the "Full screen buttom" and press "T" or "Ctrl+T", and the "Tag status" is not updated.foxyshadis wrote:It switches on and off with ctrl-T here, in both fullscreen modes. Anything else you can think that might affect it?
But, if I -for example- scroll the zoom with the mouse wheel: and press the "T" or "Ctrl+T", the "Tag status" is correctly updated.
pepemosca
Re: Tag suggestion
Only happens on the "Full screen mode".jis wrote:I haven't this problem in 1.91.5.bugmenot wrote:The tag status is not updating on the 1.91.5 in the last picture of a folder.
Can you check it?
I just realize that you have to do this to pops-up the problem.
In explorer view, select the last picture, double click over it: now you only see the picture.
Then press the "Full screen mode".
Then press the "T" or "Ctrl+T" more than once... and you will see that the "Tag status" is not updated on the "Information" in the full screen mode.
pepemosca
Re: Tag suggestion
pepemosca wrote:Only happens on the "Full screen mode".jis wrote:I haven't this problem in 1.91.5.bugmenot wrote:The tag status is not updating on the 1.91.5 in the last picture of a folder.
Can you check it?
Still wrong in the 1.91.6.
XnView 0.97.1 64bits (Oct 13 2020)
Windows 10 20H2
Windows 10 20H2
pepemosca
