In search of a font viewer
Troken
Dear XnView users,
I am in search of a free and smart Font Viewer/Utility which can display not only TrueType fonts, but also Open Type and Type 1 fonts. I have stumble across some, but there are so many, which do you recommend? Any tips are welcomed!
"The font thing" seems to be popular, but only True Type fonts im afraid...
- Forum Librarian
Troken
Thank you! Linotype FontExplorer X seems intresting. The others lack some things though. Found AMP Font Viewer, supports all types of fonts.XnTriq wrote:Hi Troken![]()
http://www.ampsoft.net/utilities/FontViewer.php
Lesmo16
Troken, you should also take a look at NexusFont.
A really fine and small standalone freeware from Korea.
English and German language files are included.
HP: http://www.xiles.net/
DL: http://xiles.net/download.php?file=nexusfont2rc1.zip
Everyone who believes in telekinesis, raise my hand!
Troken
Drahken
This one works well for quick reference purposes: http://www.snapfiles.com/get/fontselector.html
It sits in your systray & lets you quickly browse through samples of your installed fonts to find the one you want. Not sure wheather or not it works for anything other than TTF ones though.
Troken
Thank you, but only TTF it seems.Drahken wrote:This one works well for quick reference purposes: http://www.snapfiles.com/get/fontselector.html
Troken
NexusFont 2 rc3 supports Type1 fonts now, at last! So now this font manager is by far the best free font manager, highly recommended. Very easy and intuitive, try it!Lesmo16 wrote:Troken, you should also take a look at NexusFont.
Lesmo16
Troken
Thank you ZoNi, it looks nice (good ScreenshotZoNi wrote:I use dp4 Font Viewer (64kB, free, no-install)
http://us.fontviewer.de/
- Forum Librarian
Giveaway of the Day: Advanced Font Viewer
ckv
Hawkeye Font Browser
Free, small, no install required font viewer. Only minus for me is that it's an .NET application.
http://www.hawkeyetech.com/products/freeware.htm#hfb
