Support sRAW
tknterry
Support sRAW
I havent seen this one by searching for it. It will be a great improvement if XnView could support viewing sRAW files. For example with my Canon 40D when I use sRAW, the images do not appear in XnView. Thank you.
Re: Support sRAW
Could you send me a sample?tknterry wrote:I havent seen this one by searching for it. It will be a great improvement if XnView could support viewing sRAW files. For example with my Canon 40D when I use sRAW, the images do not appear in XnView. Thank you.
tknterry
Re: Support sRAW
Do you want a sample of an sRAW image? Yes I can if thats what you want.xnview wrote:Could you send me a sample?tknterry wrote:I havent seen this one by searching for it. It will be a great improvement if XnView could support viewing sRAW files. For example with my Canon 40D when I use sRAW, the images do not appear in XnView. Thank you.
Re: Support sRAW
Yestknterry wrote:Do you want a sample of an sRAW image? Yes I can if thats what you want.xnview wrote:Could you send me a sample?tknterry wrote:I havent seen this one by searching for it. It will be a great improvement if XnView could support viewing sRAW files. For example with my Canon 40D when I use sRAW, the images do not appear in XnView. Thank you.
tknterry
Re: Support sRAW
OK, Id be happy to. I cant find your email address Pierre. How do you want me to send it to you?xnview wrote:Yestknterry wrote:Do you want a sample of an sRAW image? Yes I can if thats what you want.xnview wrote: Could you send me a sample?
Re: Support sRAW
contact at xnview dot comtknterry wrote:OK, Id be happy to. I cant find your email address Pierre. How do you want me to send it to you?xnview wrote:Yestknterry wrote: Do you want a sample of an sRAW image? Yes I can if thats what you want.
tknterry
Re: Support sRAW
OK Pierre, its in the process of sending now to webmaster at xnview dot com. The sRAW file is attached and is about 8 MB so it will be slow to open initially. I hope that helps.xnview wrote:contact at xnview dot comtknterry wrote:OK, Id be happy to. I cant find your email address Pierre. How do you want me to send it to you?xnview wrote: Yes
