Can you check xnview's behavior with this file, to see whether it's correctable in xnview or if it's Ghostscript's fault?
http://foxyshadis.slightlydark.com/random/cpfaq.pdf
I have others that show the behavior as well, usually it'll eventually start responding after a long hang, sometimes it doesn't or even crashes, if I find one of those files I'll post here.
PDF hang in certain files
Re: PDF hang in certain files
I have no hand, this file is loaded correctly...foxyshadis wrote:Can you check xnview's behavior with this file, to see whether it's correctable in xnview or if it's Ghostscript's fault?
foxyshadis
