The "Find Similar files" window doesn´t fit my 1024x 768 screen.
I can´t see the titlebar or the buttons at the bottom.
The "Find Similar files" window too big!
BaldrickTheGreat
Re: The "Find Similar files" window too big!
I have not this problem on 1024x768, perhaps do you use big font?BaldrickTheGreat wrote:The "Find Similar files" window doesn´t fit my 1024x 768 screen.
