Cropped image fails to save correctly as PNG
JiriHovorka
Post by JiriHovorka »
This error occurs in XnView 1.80 and 1.91.4 so far.
When using Crop transformation (on single image or batch conversion) on certain PNG files, some images are not saved correctly when the output format is PNG. The compression level set for writing PNGs won't change the result (still distorted).
I have come up with a workaround:
Use the same transformation on input PNGs and save them for example as BMPs.
Then batch-convert the BMPs into PNGs.
XnView is a great piece of software and i thank all involved in development.
This bug is more a nuisiance than a blocker.
Thank you.
input:
output:
script : http://jovo.webpark.cz/xn/transform.xbs
all files (incl. workaround): http://jovo.webpark.cz/xn/err.zip
Re: Cropped image fails to save correctly as PNG
JiriHovorka wrote:This error occurs in XnView 1.80 and 1.91.4 so far.
Thank you.
input:
output:
I can't view and download your samples... :?
transform.xbs
crop( 0 0 91 151 )
err.zip (» Motobit Online Base64 En-/Decoder)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Post by marsh »
JiriHovorka wrote: I have come up with a workaround:
The distortion effect is related to PNG/Write/[x]interlaced setting. Cropping odd number of pixels has different result than cropping an even number (with that sample image).
It makes me remember adjusting an old television set...
