small bug?
Nico
small bug?
Post by Nico »
When open an image in full screen mode (double click from File Manager) this shows OK, but when I press "Esc" key (to close the viewer) the XNVIEW don`t close and quit. The system return to the origin file manager but the xnview stay minimized in the taskbar. If I try switch to the xnview (the minimized task) then this close.
Thanks in advance.
Re: small bug?
Nico wrote:Hello,
Thanks in advance.
When you type ESC, xnview is minimized and not closed??
